doing this atm , ^^^^^^ what stevo said........
is it just moving and modifying or am i gonna need to budget for some new/aftermarket bits
One thing I had pointed out to me , if u get a skunk2 I/M and a t/b as well , the I/M must be the same size as the t/b,
I got a 70mm t/b and my i/m is 68mm, so I have to bore the I/m 2mm, if u can't get sensors off old I/m then u will need new, if ur gasket is fuct, u need new one, so yeah, should be straight forward , skunk2 parts are cheap from USA ATM!!!
not mounted yet lol. put it on hold while i decide weather or not to to do tb and manifold... didnt wanna fit it all up just to pull it off again... especially if it needed modifying.
hey guys earlier this morning I was running the car and after a while the engine cel light came on but from what I could tell there was no issues with the engine running at all, sound-wise and checking the engine itself under bonnet while was running with the light on. I turned the car off for a couple of minutes then started it back up perfectly fine and had no light until i attempted to start driving the car on road so I pulled back and turned off again then waited another 10 minutes. This time the car did the same thing except no light after going back onto road and was good for the last 50km home.
hey just a quick 1 will a short shifter for a dc2 fit a da9???
pull the code man, theres diys on this site just search
ive heard yes, but im not sure, dc2 use those multiple bends but ours a single bend,
http://www.ebay.com.au/itm/90-91-92-...item563fdfdfd5
thats wat im using, lil to no probs and i shift pretty hard, only prob is we didnt tighten it well first time and i lost a nut atm bottom and makes ur shifter rele sloppy, so use some lock tite.
cheers
