yeah man $350 for a CAI i'll go for it too.
BTW no one knows the stock spring rate?
Hey guys what you think about running
17x7.5 +45 rear 17x8.5 +50 front on our ep3?? will the rims come out of the guard alot?
Cheers Steven
Phil from memory they're some where around 4kg front and 5.5-6 rear.
DC5's are generally 1kg front and 1.5-2kg rear heavier!
thanks man. so it seems most JDM aftermarket springs uprate the rear much more than the front (comparatively). i guess to induce more oversteer.
i got all mounts in, feels soooooo shhhaaakkkyyyy, but i still get a noise from the steering column, would anyone no the issue here? my mech told me it was cause the mounts were putting stress on the steering column so it makes noises like rubber rubbing so its squeeky, would it be a seal around the column?
Yeah, I'll be using DC5 springs as they're a heavier rate :)
Its been said various times that after market mounts cause vibrations through the car!!!! ;)
The steering wheel shake is just the centre (horn) vibrating against the steering wheel.
i understand your point - but a 2002 models with the same kms as a 05 model are having probs with mounts left right and centre, whilst no-one has mentioned a prob with FL model.
there are plenty of sports cars that get thrashed and dont need new mounts after 40,000ks - i know alot of people personally who have owned them.
when a FL model is released they sometimes make 100's of small changes based on user feedback, recalls, and common repaired problems from the previous model - so its not out of the question that they could have changed something.
we havnt seen any FL models with steering rack issues, or gearbox issues in 2nd and 3rd either. Correct me if im wrong here though, im simply stating that its possible they ironed out a bunch of issues.
end rant ;)
either way, all respect to u mate, i know u help alot of ppl on these forums with good advice. keep it up.
