mine is broken in the exact same spot lol
over tightened by previous owner, i jb welded it shut lol
must be a common problem true
basically today i figured out that the cheap interchangerable snap ring pliers work fine when removing the snap ring , but are vertually useless when installing snap ring when installing housing lol
was trying to practice on my mutilated YS1 housing with no luck =(
whats happening to the da9 meet up fellas? in melb? ;D
hey guys . i was installing a SRI on the teg it had 2 small tubes. one was for the engine (DUH) and other one for the intake manifold. Noticed that the tegs manifold had two tubes connecting to the OEM air pipe. So what i did was I got a "Y" plastic tube and connected it to one of the tubes for the SRI. Just wanted to know if what i did was right??
Yep you will be fine
Hi guys,
Tried for ages with a mate to get tranny on , got closer than ever, but wont line up flat, should it just slap up against the block flat or does it need a fair bit of persuasion???
or has anyone ever used the top three bolts to get that last few mm of clearance closed? im too scared im going to Fcuk it up,
need help please
Clutch is aligned..?
hmm... spigot bearing not on weird angle? other than the the only other thing that should stop it is dowels not lining up or wiring etc getting caught...
hey fellas just wondering if you guys know what size are the main 3 bulbs in our da9 clusters. planning on buying some amber bulb covers and i dont know how to explain it to the guys sellin em. from research ive got 1895 , 53, 74 . which of these? thanks
