Hi guys,
Does anyone know any place in Melbourne where I can bring my own xcarlink and get it installed?
Thanks!
Hi guys,
Thanks!
Really easy to do yourself. Where abouts in Melb are you?
I Bought this from ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
and follow the steps from the site.
http://www.youtube.com/watch?v=4yP3Y...eature=related
from here its exactly the same - the way to plug the wire. Just got mine (2004/Euro) done yesterday. Need bit of times to remove the console stuff (took around 45minutes or an hours to get all the things done).
Hope tis helps.
Hi guys,
Can someone please confirm which model of xcarlink ( original or from ebay ) works with sat nav Euro model?
Want to buy one, but just trying to make sure model is right.
I've just installed xcarlink into my 06 Accord Euro with Sat Nav.
I used this install guide ... it was accurate and worked a treat.
http://www.civinfo.com/wiki/index.ph...in_2007_Accord
Good luck ...
Actually ... I have a couple of xcarlink questions that need answering.
With the Accord Sat Nav model .... you don't have the buttons 1-5 below the stereo to scroll through the xcarlink folders. How do you do this on the Sat Nav Model ?
Also, how does the unit present info when you have a SD card & USB stick plugged in at the same time ? Does it read both at the same time or what ?
Im about to attempt installation on my 07 sat nav, will let everyone know of any gotchas that i find
ok so its all installed now, working good. i followed this tutorial:
only thing is, i only reconnected 4 plugs into my dvd, couldnt find the fifth, and cant remember if i even disconnected a fifth.
only issue after install aswell is the fuel usage thing jumps .3 every 5 or so seconds when the car is at stand still? Anyone know if this is at all related to the xcarlink install i.e. me unplugging or messing around with something that i shouldnt be?
apart from that, it works a treat and am very happy with it.
Guys, I am after this cable to use my iphone 4 in my accord euro 2004.
Where can I buy this xcarlink cable or similar from? I have been to www.xcarlink.com.au and it seems to be broken link
I've got the same setup (04 euro + iphone4) and just bought a Dice unit for my car, and very happy with it. Cost me about $170 landed from ebay. It allows you to flick through songs with your steering wheel buttons and headunit, or by controlling it directly on the iphone at the same time. You don't have to muck around with playlists or anything. The unit has further navigation capabilities if connected to later model headunits that support text etc, but in the 04 euro it's a bit more limited. Never tried the x carlink, but would recommend the Dice unit from my recent experiences.
Ollie
if you're looking for the xcarlink, i purchased mine from ebay from this seller. They also have a bluetooth unit that plugs into the xcarlink unit. Pauses music and plays conversation through car audio, comes with a mic too.
i've got an old ipod nano plugged into my 05, works with iphone 3/4. i have a light hiss, only audible when volume is at 0.
You can navigate the playlist with numbers 5 and 6 on the radio preset/disc stacker numbers. As well as steering wheel controls press to skip track and hold down to scrub songs.
