dyno numbers are irrelevant... take it down the 1/4 mile and run some mph
Sounds like a good idea james. I got other dyno sheets, but not sure which ones ozhonda are after, maybe Adrian should post them. But i do know that the track times are incredible up here in queensland. I would think if the dyno was done in 5th gear the readings would be lower than what they should be, who knows. Is 'one to pin' one of the highest powered k21.5 in aus?
doesnt much difference if its done in 5th or 4th, only 1-2kw differences. Yes even tho you can improve in your track time, you'll be curious to know what mph it can pull down the 1/4 mile
I guess ppl with high dyno numbers have some kind of bragging rights over their big build to justify the money spent.
Yes your car is probably one of the highest. i woiuld of still would of opted for a k24 bottom end (drh 195kw?)
as yonas said, phill's car produced 198kwatw...most powerfull NA k in aus.
as for the reason why people would go the 2.2 stroker over the k24 bottom, is that its a very strong/reliable engine with a power curve suited for the track (thats what i've been told anyway)...
I would go 2.4L anyday! I raced with the K24 (complete stock k24) at eastern creek for 6-10lap constantly on the rev limiter and it just loves it. If your car aint a dedicated race car or endurance race car k24 all the way.
abit ot but here is a short clip...gota love 6 speed gearbox
http://www.youtube.com/watch?v=Rm79CW-O7nQ&feature=channel_page
IMO the k24 is much cheaper engine to build and plus you can get the same if not more result with the same amount of $$$ spent on a stroker kit.
Check out the K24 powered Time Attack Civic in the states... simple build and quick
This is getting very political, but here are the results from my first ever time at lakeside. The times do show results. http://www.qldraceways.com.au/Admini...riesforweb.pdf
Benson give it a rest. Timmy never mind man you know how much of a difference your car is now compared to before. From the looks of things you are happy and you are whooping ass! Isnt that all that matters?
If it were up to Benson, buying Toda parts or just associating with TODA will be a criminal offense.
Dont start this shit again
Get back on topic!
