Originally Posted by
maaaaark
			anyone done a b18c2 swap? just wanna ask about the ECU and tranny. from what i know,
1) pr3 obd0 vtec ecu's would work however cant i use my obd2 ecu??? No you need a P72 ECU unless you are chipping the PR3
2) cable tranny? what do i need to convert into hydraulic?You can either go for a full hydraulic conversion with a bracket that sits on the pedal frame itself and then get a master and slave cylinder or a bracket that mounts to the gearbox or near it and actuates the clutch via cable to a master cylinder, I think the first is the best option, google hush22
3) intake manifold, change or retain ?
