Cruise control has a minimum speed before it will work.
Quote:
Originally Posted by kam
I'm not entirely sure, but it doesn't seem to work below around 60kph?
I've put it on 60kph then tried to reduce speed it wouldn't really go down either.:zip:
Mine works at below 60... I remember using cruise control when going around 60 zones with speed cameras. I'll try again tomorrow to test for the lower limit.
lol I guess honda reprogrammed cc in my06 so it doesnt rev like that. I tried getting it to rev happy, couldnt do it.Quote:
Originally Posted by xiang
Quote:
Originally Posted by aaronng
Yep mine works below 60 as well, I think the limit is 50km/h
Back. Just tested it. Mine works at above 40km/h. Yay!
When you have your euro in triptronic mode it gears down by it self when you brake.
not when you brake, more so when you reach a certain speed/rpm level...
Oops thanks for correcting me lol ;)
not sure if anyone mentioned this but the steering wheel is telescopic - it can be brought forward toward you.
yep one of the first things I noticed when reading the specs on the website ftw.
But yeah another thing I noticed while driving spiritedly, the accelerator power is limited when doing a sharp corner. lol it was a safe corner to zip around at the time, but traction control is likes to play it safe ... could of been loose gravel on the road for instance..
It's the VSA taking control of the car, you can switch it off from the button below your driver right hand side..Quote:
Originally Posted by EuroDude
Drive Safe......
