give to me ? lolz
give to me ? lolz
Bleach it ?
Nah, tie bar doesn't generally reinforce the mounting area where you would need to drill holes easiest way is probably the ASR setup. Don't know of any other commercially available alternative at the moment for the DA
i neeeeeeeeeeeeeeeeed a rep poiiiiiiiiiiiiiiint pleaaaaaaaaaase helpppppppppp me fellassssss
You haven't posted anything since your last request!
As I said last time, give us a trinket of information and I'll give you a rep, nothing comes for free!
(check g2ic and Honda-tech, lots of good info there) plus gotta stick to the rules of the forum and not just give out reps for nothing
doing a swap........
ive seen a ecu conversion harness from rywire.com obd0-obd2a with vtec wires and sensors. what do you think is better ? having my mechanic getting all the wires from the wrecked 96 vtir to be put in my DA or just have the conversion harness??
what header with a 2.5 collector would clear the oil pan and the crossmember on a b18c2 swap????
I would never swap an entire chassis and engine harness, there will an exponential increase in problems. Use the conversion harness or just do it yourself (not hard).
As for header, you can get one custom made at Westside Mufflers otherwise I've used a crappy xforce header which fit but only had 2.25 collector.
