Hey guys - just posting to introduce myself here and my car. Would be really down for making a regular meet up spot for the DA owners in Melbourne!!
Link to some pics...
http://forums.g2ic.com/showthread.ph...junk-yard-find
I see you found your way here. Welcome to OzHonda!
Welcome to OzHonda! Keen to see progress on the car, make sure you keep us updated!
is it possible to fit the cruise control system from the us version da9 into an Aus version?
ah, well that's a good start. I assume it would require the wiring to be run separately? especially since mine has the xsi harness
hey guys , is a obd1 vtec cluster a plug and play affair when i put it on my non vtec da?
Only difference is the higher redline, should just swap straight in. Standard cluster goes up to 8000 in the red area anyway so don't bother!
Hi guys,
I was wondering if the 88 model integras airbox assembly will fit in a DA9? If not does anyone has an airbox and rear hatch struts for sale?
Where are you located? No clue about the '88 air box, but something tells me it won't fit. If you're in Melbourne, I have a spare air box with resonator and intake arm.
Hey mate, yeah I'm in Geelong how much would you like for the airbox?
