Like a broken record, lol...
I guess a quick test would be to swap headers.
If nothing happens, the ports are too big.
One idea I'm leaning towards is the water injection. On my last engine b20 supercharged made160kw and then added water injection and re tuned could only get back to 150kw . Though i may gain some kw by reducing the water but at the track where temp will be up I my lose due to the high intake temps.
is it an idea to change the ignition system, remove the distributor ( insert AEM) and use K series coil on plug set up . Or is this not right and I should still be looking at current parts for issue
Don't throw more money at it until you can work out what is failing you at this point in time
Update
Buddy club exhaust is shit. Shone a light up the exhaust and found a 1 inch Pipe.... This is how much the exhaust tapered down to inside the muffler. Crazy
Added methanol to water 50/50 mix made no difference to power, tried all nozzle sizes still no power to be gained from that .. Though the exhaust was prob hurting the figures.
So I have removed the buddy club muffler and installed a 2.5 in muffler
Getting the super charger serviced .. Been racing for a few years so prob need it.
Looks like I need the cams dialed in better.. So once I get the supercharger back I will have to find the limits of the cams ( valve to valve clearance) before I start moving them..
i dont recall many people at all with decent supercharger results. i know that small cams are preferable.
stock valve size would be to avoid valves hitting eachother at overlap when dialled in correctly.
exhaust side of the head is probably the last place you want to port. you know that the air is forced out of there right? so much smaller ports are fine as the engine just pushes the air out and the more velocity the better so the next cylinder that fires can use the momentum and sucking action of the previous pulse to pull the gasses out of the cylinder.
did you know endyn actually decreases valve size in some of there crazy engines? porting is one of the last areas to look for power in forced induction.
what are your intake temps like?
i would suspect you are blowing alot of air out of your exhaust. can u smell unburnt fuel when its on the dyno and the air fuel ratios look fine? i think that is a sign of all the good stuff going out the exhaust.
take what i say with a grain of salt. i say 'i think' alot lol
good luck, i hope you get it sorted and have a beast when your done!
low compression lowers your power till you have boost.
the turbo will come in at the same time as the same amount of gas is passing out the back, but the car will be accelerating harder with higher compression ratio.
so off boost is less power. but higher boost can be had becuse you will end up with the same pressure in the cylinder when high comp low boost and low comp high boost. they will both reach detonation at the same cylinder pressures.
which is why the whole engines setup and use needs to be taken into consideration when planning a build.
oh, when i said decent. i meant, your would look at your results and go wow! thats impressive! i mean when full built setups make the same as a stock motor, thats not that great. although a built motor will last alot longer through poor tuning.
