oh sorry.. pm sent.
oh sorry.. pm sent.
the same as mine but i dont have the lil holes in mine. i found on mine (gen2 crx) it performed and sounded much better. :)
yea.. but the holes i have r heaps small... so i guess its alrite laQuote:
Originally Posted by panda[CRX]
You made a hole in your front bar with a pocket knife? *sigh*....Nick........... :(
Btw, the ribbed and slightly overly flexible nature of that sort of piping is apparently not as optimal as other stiffer material based hosing for your intake. But hey, if it works and you feel a difference, then it's all good. :)
dodgy yea... haha..lols...Quote:
Originally Posted by joneblaze
but it wont flex... coz it fits in perfectly... i can handly move it ,, so i guess its alrite...
well done nick, looks good man, your filter will work much better now :thumbsup:
Not only that, the ribbed design of the piping will technically screw up a clean smooth air flow intake, creating turbulence in the piping.Quote:
Originally Posted by |N|
yea jon i get wat u mean ... if i can get my hands on a better one... i might change the pipe.. but this ll do for now...Quote:
yea man ... now i can really feel the k&n power yo,..Quote:
Originally Posted by egSi
some turbulence is better than totally clean cut smooth walls.
think of a ping pong ball...and then a golf ball.
Which one will go the further distance with the same force applied ?
A golf ball would. Hitting both with the same 3 Wood, the Golf ball would go 200m and the ping pong ball would get dented and go 3m because its made of thin plastic.
If your talking about aero dynamics then yes the dimples on the golfball allow it to travel further because the dimples lessen the turbulence as it travels through the air but this only applies to and object(ball) going through air, not air going through an object such as a pipe.
This piping would create turbulence, thus slowing down the air, and creating more friction=heat. Please explain your theory more? :|
Anyway still if you get a gain it's all good.
Good right up |N|
Perhaps not the best example - my basic point is a fine level of "turbulence" is beneficial for air flow.(especially in more contricted areas, such as the throttle body, inlet manifold etc) Alittle bit of a rough surface is OK.Quote:
Originally Posted by KB
It's to do with the boundary layer.
At a very small level, where the moving air touches the surface of something like an inlet port, it moves very slowly. As you move a small fraction away from the surface, the airspeed starts to pick up, to the point where it's the same as the airlflow around the middle of the port.
The thicker the boundary layer, the smaller the effective size of the port and so the less air will get in.
So, to make the boundary layer thinner, you need to get it to stick to the port walls etc as best as possible. That's where the slightly rough surface comes in, it helps make the layer thinner.
It's also why golfballs have a dimpled surface, it helps reduce drag as they fly along, and makes the flight more predictable.
Its mostly theory mixed with what expericenced people have told me.
so ben r u sayin that the pipe i have now is good enf to do the job?
