Originally Posted by
fillit
You must be a Sydney boy? I've seen his car/met him at TOCAU annual (I used to be a toyota guy, but now moved on, still keep in touch with them because they are nice bunch to hang around). Yes, I was definitely impressed at what he managed to fit into that engine bay (FYI working on it was an absolute b!tch, can I say that unless you run an oil catch can the plenum can get quite oily and cleaning it requires removing the front half of the bay). Although I am a little disappointed that he only runs 12s as he put ALOT of effort into it and top quality parts. I'm not sure if he has taken it to the track yet, as I would been keen what he could do around Wakefield to give a proper yard stick.
Can I also comment on how I dislike how high you ride in the Sportivo and from memory if you run BC coilovers you have to remove the rear trim to adjust the dampers.
However, it is a damn side practical compared to the FN2R, 4 doors and heaps of boot space, also you don't get every hoon trying to run you at the lights, totally stealth.
For the records, my friend did a 1.46.X at winton with the above mentioned Sportivo with semis.. an FN2R could do that with just semi's.. Mark's FN2R from TPNM got pretty close, I think he was around the 1.47 - 1.49 range with stock car and KU31s.
