Thanks man, your info really helped (aswell as braXtas).. Going to get it fixed real sooon.. appreciate it..
i've got the same problem with my 03 euro (im in melbourne).. can anyone tell me if I buy these "new" driveshafts on ebay (for 04 - 07 acura tsx in USA) with they fit my 03 euro ?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
http://cgi.ebay.com/ebaymotors/ws/eB...ht_2802wt_1165
yeh that will =D but it will probably happen again if its the same as original one. =(
you know where i can get good cheap aftermarket ones... pedders ?
I too am now getting Vibrations under accelration from 80km/h upwards - Will book it into Honda to get the driveshaft housings checked out.
This is not a wheel balancing issue, def something mechanical.
Is the a picture of the inner cv joint housing??
http://i281.photobucket.com/albums/k.../CVJoint-1.jpg
Is this the only reason why the euro start to vibrate / shake??????????? Car is under extended warranty which is good. Worst thing is that you need to get it up too freeway speeds to feel it. Funny enough it gets worse after 10 minutes of driving..
Any type of input is welcome! - Thanks
hey, where did u get it fixed at ?
yus yus it =D
Hey Braxta,
Did you get a whole new driver shaft or just the replacement drive shaft housing?
replacement housings.
thank you for the info. I was having this shake at around 90kms
getting it fixed now. Appreciate the info.
no worries... i kept my old housing to take some good photos to show the exact problem... i got both sides done now and itssss noiiiice =P hahah
Hi BraXta, same problem on my euro, happens also when im accelerating from stop position.
So you only used 1996 accord drive shaft housings? Does Honda still sell this brand new?
Thanks.
