full inspection , basically all things on the car have to meet oem requirements , not just the defects this is more than just ur usual rego check .... wipers , fluid leaks , tire size to comply with placard , wiper jets to be full functional , seat belts (no rips/tears) lights (all) , gear knob (u need to have the h pattern on or near the knob) , body to conform with oe spec , no backfiring , brake test comply , seats to conform (proper rails/no movement rattle and has to recline) engine/driveline (functioning / leaks / loose )
If it's a full inspection by an RTA appointed inspector then you'll basically have to return everything back to stock (including your coilovers which aren't engineered).
sitta - but ur car is stock that height ... and i think its on ur placard too... ur a loophole!
It's full inspection by an AUVIS so it's ok with coils then... phew.. LOL
well there just as strict , are ur coils ride height adjs? and what size wheels are u running? bcoz u need stockers!
wdf how strict are they ._. lol umm yeh coils are height adjustable and size wheels are like 15x6.5 +45 I think.. as if... are you serious.. I got a blue slip last time with 18" chromies on the car from the previous owner lol
It's the rolling diameter that they'll have a problem with, not just the wheel size, but being 15x6.5 you should be fine as long as you dont have massively chunky or super thing tyres.
Dont stress too much, needs to meet std blue slip requirements.
Seriously peeps, you reckon all the import would pass inspection if it were "OEM" specification!
Shop around ask a blue slip place near your home and ask them what you need to pass an inspection, instead of reading the forum and stressing!
thanks yeh that sounds better hahaha
put a stock exhaust on, raise your car to normal height since u have coilovers it will be easy. Get rid of any pod etc, make the car as stock as possible and go for a test. U should pass.
I know performance exhaust has been fixing alot of loud exhausts that were defected. I'd go there cos they also have a db tester. I'm sure they will work something out for you.
Oh okay yeh, performance exhaust were the ones who built my twinloop cat back for me anyway. Thanks!
