what tranmission are you running? euro or dc5?
mmmmmm i so wanna run my K24/K20 to 8,000k...
just hope my choice in engine tuning can do it :o
EG5 what kind of exhaust set are you running??
so will the k20a intake cams + type r valve springs work on the k24a3 block ? without ecu / kpro
It will work. Also if you use the 50deg actuator the ECU will definetely get confused without aftermarket ECU control. Why would you want to go backwards using K20A cams in a 2.4? The Euro cams especially 05YM onwards have a lot to offer especially with the use of a 50deg wheel and tuning, ask Yonas:thumbsup:
