dc2r exhuast mite fight with abit of adjustment...
if anyone finds anythign i could use lemme know..
also give me some hints/ pointers on what i should do to it
If its a zc motor, it would be a single cammer Vtec (D16zc) its similar to our d16y1 found in the civic vti (eg), which means you will need d16 headers lol, those in the ad wont fit because they are for a B18c motor and not a D16, 2 very different motors.....
One thing i wont know for sure is if the civic D-series headers will clear the bottom end or not and weather it will extend far enough to the cat or not, as the teggy and eg/ek are different chassis to begin with.
But thats as far as i know... Im sure someone with DC2 knowledge can help out more
its a D series, so get d series headers. if the headers dont bolt up to your exhaust a exhaust shop should be able to fix it but they should bolt up to your exhaust.
get generic stainless headers for a D16y1 or D16z6
the bolt pattern will fit fine - all D series bolt patterns are the same - the only problems are:
1. the exhaust ports on the DOHC ZC engines (D16a8 over here) are a bit larger than the SOHC
so you need to port match the headers - fairly simple
2. the downpipe may not clear the sump/gearbox area because the ZC engines are slightly different to the SOHC ones
3. the chassis may be a bit longer than the generic civic - so you will probably have to get an exhaust shop to extend/shorten the header downpipe to match up with your cat
