Eibach and Bilstein should be slightly stiffer than your stock FD suspension.
FD's suspension is soft. Have you checked your tyre pressure? Set it to 32-34psi.
Thanks Aaronng! Checked my tyre pressure today and it was at 35psi front and rear, changed them to 32psi and noticed a big difference, much more comfy than before when I could felt every tiny rocks on the road... Thanks alot!
Well after i installed Tein S tech lowered springs on my car....noticed a big difference in handling....turn in is a lot better and big difference in handling but it keeps hitting on the bump stops everytime i go over a slightly deep bump...looking for shocks to suit...prob bilstein would be good but i have been researching and koni yellow shocks seem to have the best compatibility with tein springs...and the handling is close to coilover performance but the ride is less comfortable...well guess theres either handling or comfort...honestly i think if you just change the shocks..the handling wont be affected much as the spring rates are still the same...just bounces more or less? :P
