> is Koni Yellows running the hardest setting with Kings Low springs.
I think running the shock settings harder than necessary is a route to shortened shock life.
IIRC 1/4 on the front and 1/2 on the back was a recommended setting.
> I own a 2000 Civic Cxi Manual Hatchback
Get a second hand VTi-R 14mm rear sway bar. For the 'Value' upgrade.
IMHO, dump the exhaust uprade and go with a 26mm front swaybar and 23mm rear/subframe brace.
Then get an alignment to realize the suspension's potential. (zero toe, 2-2.5 neg camber front 1-1.5 rear.).
Nick.
