Yeah, I tried to start it a day later, then every day for a week. Theres just zero spark which would mean something is deffinately dead.. Its at the mechanics now hopefully its only the ignitor
Sa-weet!
Uhh the mechanic looked and said its the coil.. and will be 420 dollars to replace.. does this sound right?
$420 for a F@$KING COIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
I want to head butt him!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Take his mechanics licience and shut his buiness down ASAP!
F@$KIN' CROOKS!!!!
Kmart tyre and auto.. ****en idiots...
I called repco and the coil is 99 dollars... and then he said it would then be 200 dollars to fit it.. ffs
is it hard to install it at home?
Mate,it's a 10 minute job.MAX!
Can you give me some tips on doing it.. im not gona pay 200 bucks to some guy for a 10 min job lol.. sigh* mechanics
Sure!
- Unplug ya leads (mark them 1,2,3,4 so you can match them when putting it back together)
- Take off the dizzy cap
- Take off the rotor,it's right in the middle,remove with phillips head
- Under where the rotor was will be another phillips head that will need to be undone and a thin round metal thingy :) needs to be removed to make room for the coil to come out.
- Unplug the 2 wires on the coil (remembering which way they go back)
- Remove/replace coil
- Put it all back together
Take your time,patience is the key.Don't wanna go forceing things and breaking them.A beer will help with that! WORD! :)
his one might be a external coil?
standard
Nope,it's in the dizzy
http://www.ozhonda.com/forum/showthr...81824&page=106
Personnally I would upgrade to a Crane Cams LX91 coil + MSD dizzy cap.
great work Brett but just a few thoughts -
Firstly ALWAYS disconnect the battery before any electrical work on cars. Simply disconnect the NEGATIVE terminal.
you dont need to take off the leads - just unscrew the 4 x small philips heads and slide the dizzy cap off. Easy
Finally , since this is a once in a 10 year kind of issue - replace the coil with a OEM "TEK" coil from a good spare parts supplier. It should cost around $80-100 for the coil itself. Dont bother with any aftermarket brands or external coils that promise extra power etc - they simply dont last as long as OEM :)
