Originally Posted by
Sydneykid
Having race engineered EF, EG, EK DC2 and DC5’s I am in absolutely no doubt that the front of the DC5’s were by far the hardest to set up. Their limited suspension travel and ridiculous amounts of bump steer were difficult to overcome and hence took considerable time and effort, not to mention money. Their MacStrut design is the route of the problem but the steering arm and rack location and the centre mount steering arms are in many ways far more of an issue.
I personally like the EF style of double wishbone with its radius rods as I can easily overcome the typical Japanese car’s lack of caster. Slip the radius rods into the lath, machine up longer threads and adjust away. As mentioned in a previous post, the problem with the EF design is the lack of rigidity for the front mounts of the radius rods. Which is really difficult to fix, extending a triangulated roll cage out to the radiator support panel area is not something I would consider. Plus it is not allowed in most forms of motorsport.
The problem I find with the EK is the mounting of the front upper control arm and the one piece lower control arm. It makes adjusting caster and camber a real exercise in frustration. There are solutions but they are neither elegant nor cost effective.
That leaves the EG, which to me is the definitive Honda suspension system. With it's 2 piece lower control and upper control arm mounted pivot points it's easy to adjust for camber, caster and toe, very tolerant of height and with no real bump steer issues.
Cheers
Gary
