it would depend on the amount of boost you want to run...Quote:
on an ITR engine running 215HP @fly.
what does the top end of the power curve look like? does it flatten off?Quote:
larger tb helps only at high RPM, but can make substantial differences if it is matched correctly.
stock ITR tb probably too small, maybe 64 would be more appropriate?
the power is only as good as the weakest link ;)
I am running 70mm throttle body now. See this site!!
http://www.ozhonda.com/forum/vbgarag...o=view&id=2886
where did you get it bored out?
what size plate did you use for the butterfly?
also - how hard was it to port-match the intake manifold?
i didn't port intake manifold. The size of plate is the same. Just do inside of the throttle body. The throttle respond is better than before. Just $40 labour.
oh, OK, so it is not actually a larger throttle body.
i think Civic Type R is talking about using a bigger sized diameter throttle body to get more power, not just throttle response.
oic.....If stock internal, i think no need to change. If you change bigger throttle body, you need to change intake manifold as well.
i have heard of poeple boring the ITR intake manifold out too,
just wanted to know if/how you had done it...
the AEBS intake manifold is a better option when going with a larger TB for more top end power anyways... or the JG one if you have money to burn...
Y don't u consider 4 throttle bodies ??
cost/expenseQuote:
Originally Posted by edw-R
