Originally Posted by
bloodsword27
take off the little hose that goes to the bov whilst the car is running. the revs should drop as the ECU detects an air leak (unless u have aftermarket ecu and tuned on MAP). if drops, and then back to normal wen u stick it back on, then bov stuffd more than likely. if nothing happens wen u pull it off (std ecu, running afm) then something along the line of the hose is restricting airflow eg clamped between somethng or leak
btw gimme *useful post* thingo so that i can go into the trading forum (cant get in for some reason)
