yeah no prob. But look at those wires taped up - that you showed me too. There is SOME OEM wires that are spliced on the standard loom.
Yeah,I had a surging/hesitation problem that lasted 1 yr and 9 months,next to drove me nuts.
I tell ya,I know my car bloody good now :thumbsup:
Eventually learnt of the problems that were the cause:
* 02 Sensor
* Timing off
and,the biggest one of them all that clearly removed any sign what so ever of surging/bogging/hesitation:
* This!
A lot of sweat,blood and tears has gone into that DIY.I'm very proud of myself for sticking through all my surging/hesitating problems and working this sh!t out.
I'd say the increased load during the hesitation is causing the heat shield to rattle. And check the TPS like Beeza said. It's possible for them to develop a voltage flat spot. It's hard to diagnose flat spots without a oscilloscope though. But resetting it correctly can't hurt.
Ah,a flat spot aye.
Hmmm,an oscilloscope aye :)
That's what was needed to find what terminal on the ICM is + and -
If you still have the problem after calibrating the voltage or you want to make sure all is fine with the TPS,swap in a known working one and calibrate it.Then you absolutely know it's fine.
Going by this:
http://www.apexi-usa.com/content/pdf6133.pdf
I will have to remove the VAFC wires into the spliced bits and just solder/tape up the wires ?
And re-attach the VTM Signal Wire, VTEC Solenoid Signal Input/Output wires, Pressure Signal Input/Output wires so it's just going into the ECU rather then the VAFC, is that right ?
Thanks!
yeah pretty much
whatever wires were broken to install the vafc, join them up together
vtc is useless to you since it's a b16 so you'll only have the other two afaik
So I removed the throttle body to clean everything on it, put it back on and now I'm getting a TPS error :( I'm not getting any voltage from the TPS and the engine light stays on and is running rich as anything! Only getting the TPS error, I thoght it was because i removed the VAFC, but the vafc was stil on when i put the throttle body back on after cleaning the TPS/IACV, but I can't adjust it as nothing is coming onto the multimetre! :(
check to see you didn't plug the map sensor wiring into the tps and vice verca
The TPS plug is much shorter, so that wasn't the case!
Going ben's tommorow to pickup a ecu, see if that fixes anything.
if it doesn't work tomorrow, grab a pinout diagram and check for continuity in the tps wiring. Could have a degraded circuit that broke when you unplugged it and moved the wiring around. Happened to me once
Thanks for the on-going support 02gzm, but how will I go about checking for continuity ?
Thanks!
Have you checked the tps positioning????? this is a major thing alot of ppl miss, go on to the sensor check (i think) on ur vafc and tell us what your voltage is a closed throttle and full throttle (ignition only obviously)
