VASS approval stations pdf. Clicky
Technically, yes. But in this case you could almost guarantee that it would never be picked up through inspection. I also don't see why anyone would spend that much money on the engine swap when they could spend it on mods and see better results.
then i doubt a k20z to a k20a will be noticed?
B18C7's look identical to B18C's and they both have 'B18C' in the engine number.
K20Z2's look slightly different to K20A's and the engine number's contain different letters. I guess you could get away with it if you painted the rocker cover and changed the plastic intake cover but I still don't see this conversion being done due to the costs involved. I'd be more inclined to find out if a head conversion was possible. That way you'd retain the block stamp and theoretically it would be cheaper. I've slightly changed that post from before too just for future reference.
no worries mate, just wanted to make sure.
so in NSW you only need an engineers cert if the displacement increases by 15%?
As my first reply in this post states , entirely relevant as the OP is in NSW too.
Short answer
IF the car is replaced with an engine that is the same age or NEWER , an option for the chassis AND is within +15% increase , it is fine to install without need of engineering. You will have to change the engine number with the RTA.
Quote:
gli = d15b7 = 1493cc
b18 = 1834cc
so that is more than 15%
(1 493 / 100) x 115 = 1716.95cc.....
1716cc is the largest increase in capacity you can go without engineering.
Look at a B16a engine perhaps , or spend more to engineer correct front and rear brakes to suit this larger engine capactiy increase.
Hey guys, just one question.
So wt should I do with the rego if I put a B16A2 in a EG Si?? (in Victoria)
