Andy, the one from YAJ and the on that car, the position of the clock is different on each other isn't it? I think for touch screen is a bit too far.
yes u are correct. different side of driving between Japan and China. i think its far for touch screen as well and thats why i drop my own idea as stated before
its good to see someone actually did that on AUDM RB1
^^^ Andy, feel like making an appointment with the seller to view car so that we can have a play with the system...hahahhaa.
haha never thought abt that
Hi
I have 2005 Odyssey. The central upper radio/clock//audio display panel backlight has failed. I can still see LED display is working OK.
Have you any information on if it is possible to replace LED backlight or do I need to replace whole display unit?
Thanks for any help in advance.
Nmb
Easier to go to a wreckers and get the display unit IMO. Should be plug and play
page 1 on this thread has procedure how. where r u located? u want the double din or the display replacement? i'm not 100% JDM one is compatiable.
that case, try to find one from wrecker as not 100% sure they are compatible.
double din fascia below
http://www.ozhonda.com/forum/attachm...id=29137&stc=1
Hi
OK
Thanks will check with wrecker
Nmb
