nope but im going to be runnin a hydroshield
http://cache.autoanything.com/images...njen_hydro.jpg
being a honda fwd 7,000rpm in the rain = depending on gear,wheelspin and dangerous i dunno why you would first of all. Second i dunoo how you would sugmerge unless you drive in a flood area iee
http://img143.imageshack.us/img143/8...fest028oy2.jpg
or drive your car into a really deep puddle a dip in the road or pothole of that calibre. which the places in sydney i drive around i cant find..
In all if your worried about hydrolock CAI isnt for you, stick with shortram hotengine bay intake
Good point man, but to be honest I even think in this picture of your's there would be no hydrolock - the pod in the bumper wouldn't be submerged at that depth.
If you're smart you just drive slowly.
If you're super worried then just disconnect your intake at the bend where the stock box generally sits, or even at the TB, then reconnect on the other side of the puddle :)
take your intake off, get some carby cleaner, run your car on idle
drain the oil, change oil, check plugs and all that
should be fine, if it wasnt you car wouldnt be running :)
holy crap! is it just me or is that stock hp figure for the GSR on the fujita dyno really high?
143hp isn't too bad for a healthy motor
edit; i take that back, does seem a bit high for a stock gsr motor, seems more like a c5 figure than c1
in my old lancer i had a cold air intake.. i had a scare once when i went through a puddle and the car coughed and splattered but came out fine after about 15 seconds... although the new owner sunk it within a week of owning it... when it rained alot o just took the bottom half of the intake off and ran short ram
lol if you go through enough water to completly cover the pod, id be more worried about the water coming through the doors :)
