I agree with you.:)Quote:
Originally Posted by SP0017
Some info:
4.40 66/15
4.785 67/14
4.929 69/14
Some info:
4.40 66/15
4.785 67/14
4.929 69/14
Ok.. The teeth count of the AUDM DC2R final drive on the bench showed 67/14...
That makes it a 4.785 final drive...
I guess the AUDM DC2R Honda workshop manual I've got is wrong...
Sorry for jumping in on the W/E & saying 4.4 off the bat...
Cheers
Adrian
The civic VTiR and the Integra VTiR is 4.4
Can Integra VTI-R install ATS fd?? And what are the parts no. for Integra VTI-R??
you need the above to work it on a vtirQuote:
Originally Posted by TODA AU
Seems like it's the same parts that needed to install the 4.785 FD
Someone above asked if 4.9 to 4.7 a noticable difference. As my type R is my first ever manual car i bought i really cant tell the difference. I can tell you the rpm goes up pretty quick. My few of my friends drive my car and they were suprised how close the gear ratios are. If that kinda answers your question. Although none of them drive Type Rs.
Forgot to mention when i bought the car final drive was already installed.
as i said , i was just sharing wat i heard , im not very sure myself. So yeah , not trying to write up some BS.Quote:
Originally Posted by tanghy
Anyway , i myself very very confused. I have a 2000 ITR and ppl tell me its 4.4 , and some tell me its 4.7
WAT THE HELL IS THE FD ????????????????????????
4.785
so since 5.06/4.785 = 1.05.. that is 5% difference.
so in any gear your rpm will be 5% higher.
at 120km/hr (like in the country) the thing will be spinning at almost 5000rpm right? fark.. that is a bit high.
That's why someone put 96 spec 4th and 5th gear back on.......Quote:
Originally Posted by 00dc2
and also i don't think 4.9 are any good for street use
wouldnt the 96 spec 4th n 5th gear make it rev higher on the freeway?Quote:
Originally Posted by spoondc2
Oh sorry, i mean the reason why ppl put back 96 spec 4-5th gear back on is they want closer ratio, 5th gear is not necessary to swap cos it's just kinda downgrade, they swap 96 spec 4th to their 98 spec 4th cos they want better accelerations after changing gear, but anyway it is bit silly to swap both 4-5th gear cos it's just exactly the same as having a 96 spec gearbox and equipped with 4.785 FDQuote:
Originally Posted by weezer
Sorry to make you confused :p
Anyone has experience using the whole ATS gearbox set?
