Originally Posted by
FastFwd
K so had a bit of probs with my car but finally got it sorted.
Got a new Exhaust put on... Originally had 3inch turbo back with mild steel..now i got 3inch turbo back fully stailess polished with new cat, new plumb backed screamer pipe etc.
went to the engineer today and he passed almost everything on my car. List of like 80 modifications. Only two things i have to do is i have small break fluid leak on one of the line connections which will be easy and my new exhaust sits 4mm to low which was the exhaust shops fault to they fixing for free obviously.
Engineer passed my carbon fibre parts, bonnet, wing, boot etc. Passed my turbo setup, front mount, Engine swap. I was scared hey, people say they are pretty harsh but my car is pretty clean and he thought everything was nicely installed and he's not even that expensive.
all i need to do, is fix those two things and then get a 5 gas test and i can get my yellow off.
the engineer also reckons if i bring in my racing harts he will be able to certify them also. I told him they dont rub or touch and they have alot of clearance for 10.5's wide as ive opened the width of my guards and he said shouldnt be a problem even if they are more than 2 inches larger than stock.
