NSPYRE great work, rep points for u sir. good 2 see some nice pipol still on forums, that dnt attack wen pipol wen they get confused about specs and what not
just putting it out there, got some buddyclub spec3+ in my b18c7 with the regular ihe with a 65mm tb and some cam gears(forgot what they're dialed in for)
felt about the same with the stock ecu, way more responsive after a proper tune
had about 10-15kw gain everywhere after tune
tune price doesn't matter since it goes from tuner to tuner
Anyone got any experience with Brian Crower products?
http://cgi.ebay.com/ebaymotors/BRIAN...Q5fAccessories
fgk powergetter for sale here. for dc2, quiet quiet no defects and good gains! cheaper than buying cams, computer, tune...
I go +1 for the FGK PG. I picked one up cheap for my brother's DC4 with a 2.5" Magnaflow cat. Quiet, good gains, doesn't hang too low etc.
hey guys, i have a dc2 vti-r 95 model. At the start of this year i did.
Blox B cams
Blox Dual valve springs
Blox retainers
Blox cam gears (set to +2 degrees intake and +1 degree exhaust)
Skunk IM + 68mm TB
T1R headers
Full 2.25in exhaust (Crappy custom job)
Injen CAI
Full port and polish (Port matched in and ex with machined valve seats and modified valves)
Hondata S100
Toda tune
All up it cost me about 4.5k. Whoever was asking about a tune it cost me about $1350
The car just made 131.4kw at the wheels
The blox cams are good, nice idle, a little bit lumpy if the idle is set to standard but mine is set to around 1100rpm so its quite smooth. The power is really good and its nice and responsive aswell.
The specs are 12.0mm lift exhast with 266 degrees duration (vtec) and 12.4mm lift intake with 266 degrees duration (vtec). Im not sure about the primary lobes but im told that theyre slightly bigger than standard.
If you guys are sceptical about the power output, Yonas from JDM Yard has my dyno sheet.
Thanks
Joe
