LOL...Vague memories... Sorry, I tune a lot of cars :p (It's easier to remember with faces & names rather than internet nic names - I never remember who is who through that)
If they're new, I'm barking up the wrong tree...
If they're re-used, there is a chance there is seepage past the head gasket.
The magic blue liquid will tell the story.
& the fix could be a simple as swapping out 1 head bolt at a time & replacing it with a new one & a magic tablet for insurance ;)
Magic tablet (powder) -
http://www.seallock.com.au/seal_tabs.html
Magic Liquid -
http://www.vektools.com.au/lisle-com...or-p-2725.html
If I'm wrong on that,
Pressure test the cooling system & confirm there are no leaks.
If no leaks, you may have an air bubble in the head/engine & you need to burp it.
You can do the with a cut down 1.25L Coke bottle, a roll of electrical tape & a bottle of water.
A slight slope helps too.
Park the car nose up, cut the bottom out of the coke bottle, tap up the cap end with elsectrcal tap to increase the diameter to fit in the radiator neck.
Fit & fill with water well above radiator height, (approx 5cm from full)
Hold in place & start car(run)
Be sure to have the heater on too so the water flows through the heater core too.
