i hope you realise, you're most likely spending money for sound only, the exhaust isnt going to give you much gains, if any..
In a way it is helpful. If he was doing it for the sound and was a super noob he would realise its not worth it and save some dough.
i dont think its a silly comment. Putting an exhaust on a car like that will prob give you 1kw. Its not about performance increase with this car. It will give you better flow but very minimal difference.
Maybe I should test. Dyno my Civic before and after cat-back :D
Sorry had work haha. Yeah exhaust is done, got it done at radiant exhausts which is a 3min drive and they did a good job. The twinloop sounds like a cannon sort of without a resonator just not as loud. Once u pass 2700 revs it sounds like a sss pulsar with an exhaust. Cars not running atm was changing tranmission fluid and engine wouldnt start. I think i accidentally disconnected the transmission ground, had to rush to work in mums car so no clue. Will check and post back later. I turn the key basically and all i hear is fuel being pumped from the fuel pump but no spark or anything xD.
Anyways fixed missed the exhaust sound =D
