Originally Posted by
TbM
What engine do you have? ill check my manuals and see if ive got one on your engine but if your not very mechanicly inclined you should take it to a mechanic to have it set properly.
Also i noticed on the first page you said you have a CEL reporting a faulty TPS, then when you tested it, it reported no voltage. Did you check the plug/connector for the TPS was getting the correct voltage? if it is then you need to replace your TPS as that has potential to cause your car to rev hunt while accelerating as your ecu is not getting the correct throttle position signal.
