No you cant champ...
I have Ek4 loom and Rear bracket if need, please pm
this should be some how posted somewhere for everyone to know !.
also seeing as you know your stuff, im not sure on this but is this true ?
-you can go upto 0.2L with out getting engineer cert (1.6L to 1.8L) ?
-and how about brake upgrade do we neeeda to upgrade it inorder to be legal with the engine etc for a p plater?
This is most likely a noob question but if you have a mechanic you trust not to rip you off, can they order another engine for you and install it (Considering that a D16 to a B18 swap would take a fair amount more knowledge than just installing the same engine again when the old one has died)?
does that mean when i do a engine swap to a h22a and go on red P's does that mean that its not legal?
Yeah illegal. I don't think you're supposed to modify anything at all as a P.
In Victoria the only engines that can go into cars is the engine it comes in with different models.
Say for ek best motor youcan put in is b16a
For eg is d16a
Dc5 is k20a
In saying this it's only the motors in audm cars. So if you have b16b you can't put it in ek. Only with eng cert you can. Which goes for any other engines swaps.
I can get you the link to vicroads stating this if you request it
They can register b18c in your eg or ek. It's just how lucky you are cause I went there before and they said if it's 4 cyl to 4 cyl it's ok. So they obviously don't know. I'm just telling you whats on the paper
qld cant drive a car with an engine mod plate., but you dont need a mod plate if the engine is 0.2L bigger then stock motor there fore b18c/ b18cr is legal :)
P platers can drive anything in Tassie,common to see red Ps on R32/3 s with big turbos etc.The only P platers driving 4 cylinder Hondas are girls.
