tyres are very good in wet!
For those in Vic, I had two of the re002's fitted in Derrimut Bridgestone for $186 (per corner) for 205/55/r16 - as for a review, took a few hundred k's before these tyres really woke up, and when they did, they stick like shit to a blanket.
Grip in the dry in sensational, however haven't had a chance to test them out in the wet.
Good tyre :)
Contact Advance Tyres and they are in Richmond Vic.
http://www.advancetyres.com.au/
Got quoted for these sizes:
215/45/17 re002 $200 each
225/45/17 re002 $229 each
Provided you drop the psi , they will hold up for a good 5-6 laps of hard driving without much change. Once they heat up you simply slide - the same applies to ALL road tyres....I was doing consistent 1.15s in the R on these and if you dive in alittle too hard or break too late these break traction easily. I feel i can find another 1.5-2.5 seconds per lap on these tyres but no more- loosing too much speed in the final corner (in understeer).
These are NOT track tyres. These are great street tyres thats all.
Ditto with the RE001's - i went on with standard psi and didnt touch it. These RE002s are noteably softer than the RE001's. Yes I dropped the psi alittle to get the best times - you really noticed it at the fish hook and final turn (where most speed is lost in the civic) As for the sidewall , I think it will take abit more experimentation to get the best pressure combo. Not as stiff as the RE001's.
Costco prices!
http://tapatalk.com/mu/3aa3afb5-7952-9995.jpg
