I would have to agree. This guy does just not understand what he needs to do. If you cant work out how to use your hood you should probably return it.
yeh u said something about the bonnet pins, is that the 2 pins that u lock onto the bonnet and the car so then when u go at fast speeds ur bonnet dont flip up.?
cause i think u drill the hold some where around ur radiator support, or directly on top
Can you take a pic of the latch on the underside of the bonnet? They are normally adjustable for such problems that you are encountering.
You need to adjust the latch that is shown in your photo, there are 4 bolts which you losen, this then enables you to move the latch up and down. Move it up a little, tighten it, then close the bonnet and see if its any better. Repeat it if you need to go any higher. Also don't forget to adjust the rubber stoppers on either side, these screw in or out with your finger also to adjust the height of the bonnet.
i can close every Honda I have owned with slam the bonnet man
i think it is the problem of yr cf bonnet
Case Close I Fix It!!!!!!!!!!!
The Problem Was My Injen Cai I Mount It Too High. And I Have To Ajust The Latch.
Well Everything Is Done Now, Thxs Guys!!!!!!
take new pics of CLOSED bonnet now..
:p
learn to type..............probably
aherrrm
I mean PROPERLY
LOL
