http://www.youtube.com/watch?v=5JM5k...e_gdata_player
This is screamer
This is screamer
On idle and revving, there is no heavy load, therefore the boost will be below 8psi. If you have a hks ssq depending on the spring setting, the bov will remain shut (if spring is hard) which will cause the boost pressure to return back into the compressor housing which will then cause your internal/external w/gate to release this rather than the bov. Hence why u get the flutter sound put of the intake filter or screamer pipe.
But if your bov spring is not as aggressive, then you can hear this both in the filter or screamer pipe or bov - just all depends on boost pressure & boost load.
Ninja - your def right its a hard one to explain, as ive seen many forced induction cars and they all work differently and will also depend on quality of parts, engine components etc etc the list goes on aswell as the debate..
Lol
You do realise that air cannot pass through the compressor side of the turbo onto the turbine side right?
The wastegate has nothing to do with the intake or charge air. The wastegate controls the amount of exhaust gas that flows through the turbine housing, which in turn determines the speed of the turbo and the amount of boost created.
DL's explanation is accurate. The flutter is more apparent on smaller or highly efficient turbo setups because they spool quickly without a large amount of load.
The T28 is a small turbo so it only requires a small displacment engine to spool it quickly. I get a lot of flutter on my falcon since the GT3582R and 4L motor is a similar turbo-motor ratio
Yeah but some bananas run screamer pipes on dailys
I didnt say it had anything to do with flutter :p
Sorry I should've quoted XB16AX
Looks awfully like direct knock off of HKS SSQ ;)
Heres how the HKS operates to give some ppl a better understanding... ive had one on turbo b4, sounds nice, and defs well worth the money, and i mean buying the original one lol
http://members.generationdub.com/footose/hksworks.jpg
Holy shit, 3 pages on "flutter"
Only OzHonda.
If it's that much of a concern then:
http://i123.photobucket.com/albums/o...8/IMG_0053.jpg
http://carphotos.cardomain.com/ride_...0009_large.jpg
http://www.myfacewhen.net/uploads/1297-problem-meme.jpg
And anyways u fail to see the bigger picture here....
