if you are using the stock exhaust then that should be fine as it is a single straight unit as opposed to the fujitsubo exhaust I have on my car which comes in sections and are bolted at flange points.
if you get the progress rsb, there is a bit of drilling that needs to be done as the screw fittings are 10mm as opposed to 8mm on the stock car. In general it should be a simple diy as mine was a little bit tricky i had a shop do it for me.
