try flat shifting... that way your not taking the load off the engine completely
narrr cant afford to waste money on new syncross! and i dont think power shifting will reduce wheel spin?
ive always thought the Potenza RE01R's were a very good street tyre.
only downside is the wear rate... so ill probaly hit up some AD08s after
RE01Rs are marshmellow street tires, on par with AD07s...
AD08s, RE11s, Z1s, etc are just the latest crop, performance improved some as you'd expect...
If you believe wear rate is bad on your RE01R, you won't get much difference out of the AD08s etc...
