You can get a professional paint job in the backyard. it's not hard. you just need to take your time.
- Use 2pack paint if possible. the quality and durability is far superior than acrylic. despite what many say, 2 pack paint is no more harder to spray than acrylic nor is it any less forgiving with paint errors.
** if you get sags or runs in your clear, just wait until it fully cures and block sand them out with 1500 grit, then 2000, after buff. same procedure with fine dust or bugs.
** use a tack rag to catch dust and over spray between coats
- Buy a decent spray gun. 1.4mm tip for base/clear. 1.8mm for 2k primer. buy gun regulator and set to 35-40 psi.
** difference between low end and high end gun is bigger spray pattern, durability and spray quality straight off the gun.
- You can get away with a small compressor for backyard jobs. you can get the job done with a super cheap auto 2.5 HP 40 LITRE TANK. all you need to do is split the job into 2 or 3 parts. for eg. spray bonnet, fenders, bumpers today. tomorrow paint doors and trunk. then day after paint rest of body.
** just make sure it's the same batch of paint, same mixing ratio and similar temperature when spraying. or else the shade of colour may be different.
** Frequently drain the water out of compressor. use a water/oil filter, best spot to mount is 7-10 metres at the end of air hose.
- Base coat mixing ratio is always 50:50 or 1:1. for eg. if you have 1 litre of base, then you mix 1 litre of 2k thinner which then makes 2 litres of sprayable paint.
** Clear coat may vary. but usually 2:1 ratio. add 10 - 20% 2k thinner.
** Don't forget to use a paint strainer.
-When spraying 2pack, make sure you wear a respirator. NOT A PAPER DUST MASK!!! very toxic paint. use brand such as Sundstrom or 3M. make sure you don't have people around or any neighbours.
** check with your local council if spraying 2 pack polyurethane paint is allowed.
