As I finished my testings with FlashPro unit I can confirm that it works with our CL9 Euro (2003-2008 years) without any problems. What you need (same as TSX 04-06 owners),
two items:
*Acura TSX ECU 07-08 AT or MT, depends what gearbox you have (possible to get used for 150 USD if you search hard)
*Hondata FlashPro unit for Acura TSX 04-06 (Marcus from Heeltoeauto.com can offer you)
Also Honda dealer required to pair you immo to new ECU (For CL9 euro 2006-2008 users OEM immo module works, didn't had a chance to test 2003-2005 but I believe that it will work also)
Hondata instructions:
http://www.hondata.com/downloads/04-...le_install.pdf
Starting from new Hondata FlashProManager V1.2.8 (beta) you can disable EVAP errors, so no more any "Check engine" lights in dashboard. Big Thanks for Doug that he made such option for us.
Benefits - you can tune your engine as you want, VSA works, Cruise control works, no any "Check Engine" lights in dash. Who are interested in engine tune it's mod number 1.
For me it's better solution then dual K-Pro setup (I had it before).
Ask questions if need help to setup or tune ;)
