Won't matter if you buy a manual or auto EG. Your H22A will use shift cables instead so you have to change the whole trans setup. Unless you're going for resale possibilities, then go for it.
When you buy the engine, make sure you have the engine side loom with the resistor box for the peak and hold injectors. If you buy an EG VTi, then it's no problem as you won't have to wire up the O2 sensor. But, you will need to run new pins/wires out of the ECU for the 4 wire O2 sensor as the EGs use a single wire O2.
Have your pick of mounts. Hasport is most people's choice these days. Otherwise there's Explicit, Avid, eGay (not recommended)...more but I cbf finding them for you.
Axels. Again, there are reputable companies who make swap axels. Otherwise you can mix and match.
AC and PS can be kept. Just buy the right mounts. Innovative (here's another maker of swap mounts) make relocation/AC mounts. You can use an MR2 electric PS pump so save space too.
I don't know if I forgot anything. Ask away, other use the google magic.
