ermm.. spoon make stroker kits. We have one in our drag crx.
How much kw increase from B20B with B16 head??? what is the budget of this conversion including the B16 head??
my rough budget is $5000 im in no rush to built it its a rough amount to just built a motor block and head complete not put in car i can do that myself thats no problem.
cheers,
LowEk
Quote:
Originally Posted by Macros
unless it is for a drag car where money is less of an option ;)Quote:
Originally Posted by tinkerbell
B20b block + K20A Piston...and B16 or B18 head, with Type r cams and all...cheap and good...Type R manifold and tb as well...and a programmable ECU ofcourse...injector and fuel press is needed..fuel pump and injector ballast...
total cost you less that 5 k i think....piston + rings is cheap...block itself is cheap...2nd hand Type R cams is cheap...get everything 2nd hand except the piston...hmm..may b 5k is already good to go....
use a B20b block, redo the Crank + balance...go for 86mm piston (wats the STD size of the K20a piston? 85mm or 86mm? tell me if it's smaller..hehehe..)...you don't need to go thru the hassle of what ever B20 crank in a B18 block...waste of money...but anyway...I think it all sum up to good workmanship when u considering reliability...
pgclee - pls post any links to people who have used k20 pistons in b series block
thanks for all the info on this ill prolly take my time and build a good bottom end it will b worth the time and money spent.
cheers,
LowEk
Quote:
Originally Posted by ProECU
sorry to dig up the dead, but i'm just wondering how much more advantage the b18b head would have over the b16a head in this sort of application? Also, would you be looking at cams as agressive as toda C for example? or something more like CTR cams?
definalty from the DEAD 13-03-2005, 05:26 PM.......La
yeah...... proves i was searching though, instead of just starting a new thread :DQuote:
Originally Posted by LowEk
the B18B head is non-VTECQuote:
Originally Posted by EGB16A
it has no advantage over the B16A VTEC head.
