PCV valve failure or oil leaking out through the oil filter gasket seal. Only leaks while driving (oil pump supplying positive pressure), so the oil does not appear under your car in your parking spot, but rather in a trail as you are driving along the mountain road under heavy throttle. When you go back there next time, see if there are any cars that slid off the road after driving over your oil trail. :)
