That's mostly because they aren't using the right lug nuts and isn't sitting correctly on the stud. This makes the wheel slightly biased toward a particular direction causing it to be unbalanced.
I find hubcentric rings help position the wheels correctly, 100% of the time and is worthwhile if you can get them. If you can't just make sure you are mounting it straight.
