hmm..hey dave
how loose/ tight should ur cable be?
woul dit affect your idle if altered?
hmm..hey dave
hahah i didnt bother with your other ones :p... well theres a debate at the moment that whether there can be a difference in engines when they come out of the factory.. imo, i reckon yeh there is the possibility.. double clutching?... search my friend... thousands of threads!! :)Quote:
Originally Posted by quangsta
check in the "Track / Drag Racing" Threads... just search :D
just get the 2 guys to swap cars, then have a couple more runs, easy way to see if its driver related
you should be able to move it ('deflect it', ie push it downwards) about a few mm, maybe about a 10mm or so.Quote:
Originally Posted by hong_ung
you can have it tighter, but it might not close properly (it needs to be able to 'snap' shut) - this will affect idle, but idle WONT be affected if you cabel is too loose
if it moves more than 15mm or so - you are probably not opening the throttle up all the way when you put the pedal to the floor, you might only be getting 90% or full throttle, and therefore 90% of full power!
you need a 12mm spanner to adjust it.
(i can see all you peeps checking your engine bay with 12mm spanners after reading this - good luck :) )
There are heaps of reasons,
1.both are modded differently
2. Difference in fuel
3.Toatal weight of car+driver+fuel+stereo+etc
4.Tyres and pressure
5. Rims
6. Driver skill(slow releasing of clutch or slow to shift up)
7.Freaky motor
