Originally Posted by
Rage King
I think that kenwoods are entry level seeing that its only got 1 pair of rca sub/rear pre-outs with 2v.
U can still use this HU to run 1 amp and 1 or 2 subs..
Again, it will come to the decision on how much bass/power you want to hear/feel. The amp will be your biggest challenge.
My suggestions would be;
Buy the pioneer package that comes with the 6inch speakers $130rrp (approx). This HU has way more options with regards to high/mid/low filters / frequency settings built in the HU. As well as for the sub control too.
Unlike kenwoods they only have high/mod/low without the option to finer tune the frequencies and gains.
Amp;
If your planning 1 sub @ 4ohms the a 600wrms amp will do the trick.
If 2 subs @ 4ohms each then a 1200wrms amp will be sufficient.
Then if you plan to much round with DVCs then you will need a much higher amp output.
4gauge amp kit will be sufficient..
0 gauge is way too big... Unless your planning to run a 3cap farad...and enter the sounds offs at the auto salon comps.. Lol
