Originally Posted by
Stevil
GAB SS can be ordered with any spring rate, mine came with 7/6kg, after driving for a 4 months and doing a few track day I upped the spring rate in the rear to 10kg and then just recently I upgrade the fronts to 10kg also. I managed to bend a front shaft on the coilover ( stupid offset +42 at the track cause the tyre to rub so bad I actually bent the shaft, im talking sweeping left hander at 140kmh) suprisingly the coilover still worked fine, but due to the bend the Camber couldnt be set properly and the camber would actually change thru compression ( made braking at the track difficult ). Bottom line Gab supplied me with a hold new Gas insert and shaft for under $100. Couldnt be happier with them for the price.
