3mm isnt a problem on stock studs
5mm too mut m8
8mm fuark beast m8
5mm too mut m8
8mm fuark beast m8
Yeah just thought maybe nobody had used washers because people never have a need to space out 1mm extra. Will order 3mm now
3mm spacer ordered, correct pcd and centerbore
http://images.sodahead.com/polls/0/0...lFaceForm2.png
spoon calipers...
but srs good choice on the hub centric spacers..
Wish I didn't need them, but for piece of mind it's worth it
causericecar
Studs too?
I would... For maximum mating surface between nut and stud
Not for 3mm, still a fair bit of thread there, anything bigger id get studs
yeah no point extended studs for 3mm.
sorry but why do u need spoon calipers ? The name ? Or the design ?
Because im certain - unless your car is making 400kw atw - that standard OEM brakes are sufficient :)
For the money i definitely would of invested in a 2 piece rotor design and or BBK setup such as racingbrake , willwood etc
