Originally Posted by
ceekay101
Hey mooshie just following up how the oem plus ford friction modifier is going?
The penrite 80w90 when cold is so bad it even crunches. Even actually coming out of gear is difficult. So I decided to try penrite 75w80. Initially ok cold and hot. But after a day of driving It started clunking again I guess the 80w90 finally came off the clutch packs, that stuff is so thick it doesnt even drain out of the box quickly. Chez you mentioned ulx110 75w90 which I can't seem to find, only the 80w90 comes up on their site, can you confirm?
There are very few if any 75w90 mineral oils. May have to settle for a semi syn or go oem mtf with ford modifier as mooshie did. Or even try 75w85 penrite pro gear oil however that is fully synthetic from memory.
