It wasn't these guys - I was referred to them by the audio fellas because they didn't have a reader.
Steve
Yeah well I located the 3 pin connector - and that was the one they tried to plug into. Google says that that is the wrong one - should be 2 pin. Anyway - strangest thing - since I located the 3 pin and pulled out to where it was easy to get at - the MIL has gone away ?? :eek:
Steve
Probably not
Find that blue connector and short it out
See if the ecu still has the cel stored
If you shorted the 3pin blue connector and the MIL went away you probably killed your ECU.
Oops :P
Good, you can only use that connector for the a compatible scan tool
Hey Guys
OK - here's the latest. I was finally able to get down to the blue plug - and to my surprise it wasn't a 3 pin - but the 2 pin (really hard for a guy my size to get in close enough to see). Anyway - I could also see what appears to be some mangling of the figure 8 cable and looks like a sleeve over it? This makes me think he has accidentally cut the cable and rejoined it - OR squashed it when he was installing my head unit! :thumbdwn:
So - I used the paperclip on it and got Error code 12. Anyone know that one?
Steve
Everything you need to know can be found here
http://www.ozhonda.com/forum/showthr...gnostics-Codes
